Create package file (*.PCF) from inside teamcenter
lklo
Industrial
DK
Hi -
Does anybody know if it will be possible to create a packagefile stored inside a dataset , from a teamcenter client.
Afterwards it should be possible to download this *.pcf file to OS system , and fire it up in ExpresReview...
lklo
hi Didier -
I will look forward for this...thank you so much...
thanks in advance....
lklo
Do you mean without open it in nx manager ?
hi -
Yeahh - what I mean is , that when the *.pcf is downloaded from teamcenter , it should could open in the standalone application "ExpresReview"...
In NX native - it's possible to export a drawing and assembly via command "send to package file" - afterwards this command will launch ExpresReview and open the exported *.pcf file...
But in NX managed mode - this command does not work proper - and my question is - that maybe it will be possible to simply generate a *.pcf file from inside teamcenter, and maybe it also could be stored inside a dataset....
But I don't know if teamcenter (v10) - support this *.pcf file functionality....
also see attached pic - I found some information on internet - teamcenter Express and *.PCF files....
lklo
 http://files.engineering.com/getfile.aspx?folder=979a2aab-1967-4dc9-8b9e-3fd3c1b018b9&file=teamcenterExpresReview.JPG
Ah!
Sorry I can't help because I haven't that tool.
(we have Tc8 and nxmanager semi combined)
Thank you for the explanation.
H,
Sorry for the delay.
I don't find Xpresreview integration for rich client with a standard teamcenter installation.
I found it with a Rapid Start Installation. I will install it and let you informed
Didier Psaltopoulos
Hi Didier - than you so much for your effort in this thread.
Looking forward to get informed from your tests...
( I tried googling Rapid Start Teamcenter Expres Review...)and found this :
Looks interesting.....
Seems like something can be used..
Lklo
