I would know if it is possible to create a set of elements by using their corresponding nodal coordinates or by using a command (for python script and/or for inp file) which creates a box (defined by 3D coordinates) that contains the desired elements.
Certainly, I can't use the "*ELSET" (inp file) command because in this case I need the element number. The case explained above refers the case which I know the coordinates of the element but their element number is known.
Thanks a lot for your time.
Emili
Emili
