This question has cropped up on another forum and since I have intimate knowledge from a practical point of view... I've been sponsored, off and on, by a balance shop for nearly 30 years and have learned to do much of the actual balance work...
The question is, how much added counterweight is necessary to stabalize a three main crank as in my 1380cc Mini? Currently I am using a "name brand" EN40B design as in the UK race series with a friction damper and a <8 lb. flywheel/clutch, 14:1 CR, 7600 rpm rev limiter and, so far, doing just fine with it. (Knock wood)!
Several racers have questioned the counterweight design and have submitted some rather odd designs as "better". One such design is the Graham Russell ($5000 Australian) billet crank with eight counterweights (as opposed to my four)!
My question is---Will adding additional counterweights aid my little the three main crank at speed...Better? Worse? It certainly will effect my bank account!
Rod
Rod
