cmbyrd77
- Aug 4, 2010
- 79
In ASCE-05 it states that the lateral and longitudinal forces shall act at the "traction surface" of the beam. What exactly defines the "traction surface?" I have two wheels on each side of the bridge beam. The wheels are spaced approximately 54" apart. The max. wheel load is 4,843 lbs. So do I also apply the lateral and longitudinal forces right at the wheels, therefore have two loads that are approximately 54" apart, or do those forces only get applied in one location. Thank you in advance for your help. This is my first crane runway beam design.
