StructuralEIT
- Jul 13, 2019
- 2
I am working on designing a concrete connection for top running crane girder which is sitting on a concrete wall top throughout its length.
I am a little bit confused but needed some advice when it comes to anchoring it down to the wall.
This girder spans along the length of the wall (80') and sits on it . So, I split it into approx. 15 feet spans so I could tie it back to the adjacent columns. However , for anchoring it down to the concrete , I was thinking to use 1.5in epoxy grout pad and a bearing plate on top of grout pad and beam flange anchored down to the concrete through bearing plate.
Should I really be doing this or let the beam straight on wall as that won't introduce any strong axis bending. But in reality wall top won't be that straight. So what is the right approach for this ?
Thank you.
Thank you.
