Cap plates on columns that support runway girders should be flexible enough to allow the ends of the girder to rotate. (pinned ends)
This means, the plate has to be thin enough to prevent yielding the extreme fiber so it always remains in the elastic range...or so I believe. Would any of you bump up to grade 50 plate material in order to not have an overly thin (<3/4") cap plate? Grade 50 is less ductile, but if its kept in the elastic range I'm not sure it'd be a problem.
You can easily meet all normal girder deflection requirements and still have an end rotation on the order of 0.005 radians.
