metengr,
The designator K4 according to TriMark is the same as a H4 designator. It has the same Hydrogen dissolution rate of less than 4ml/100g. Sorry I guess I stated that wrong in my previous post. I should have stated that the K4 designator on our weld wire is = to H4.
Sorry I want to make sure I understand this, you mean you've rejected the raw wire or did you reject products built with it due to bad welds caused by the use of this type of wire? And if you rejected the wire, do you mind me asking who the manufacturer was? If it's the same one we use I'll have an easy time of convincing the weld group to test the wire stock.
My next question, the current theory of our tiger team is that insufficent removal of tack welds is the main cause of the tranverse cracks. What do you think of this theory?
