Remember that crack movement may be a 3D movement. That means one plate of the gage could move against the other or move away from it. So, when placing them, try to position them such that they are not pushed against each other. Also, doing it this will allow you to measure any out-of-plane movements. One last advice, if you know one side is fixed (no movement) and the other side moves, put the clear plate on the side that moves.
