How do you assess the crack-bridging ability of a waterproof membrane assuming there are no cracks to begin with (i.e. if the original crack width is non-existent or 0mm)?
A discussion on this can be found in the links below:
1. 2.
The following extracts sums up my dilemma:
From 1) "Cracks that form in concrete following application of the membrane, obviously have no membrane distance that is not bonded to the substrate. In other words, there is no bond breaker to provide a section of unrestrained membrane. The original gap is non-existent or 0 mm and regardless of the elongation properties of the membrane post application, cracks will result in damage to the membrane."
From 2) "When the waterproofing membrane is securely adhered to the concrete substrate it cannot elongate. It is stuck firmly in place and no longer has the ability to stretch. If a crack occurs in the concrete substrate under the firmly adhered lining the lining has very limited surface area over which to elongate and it cannot elongate as it could when it was in a free film state during the elongation at break test."
It appears the general consensus is that if the membrane is installed before the crack forms (as you would expect in most cases), then the membrane will be significantly more susceptible to tearing, than if the membrane is installed after the crack has formed (for example, during remedial works). But there is very little guidance addressing the former, which is what I need to determine the compatibility of the membrane with respect to calculated crack widths.
1. 2.
