We are designing a part for a client. This is a cylindrical body with a threaded counter bored hole. Originally I had the outside edge of the part designed with a chamfer (the client had this on their preliminary drawings). Now they wish for some freedom to make this corner either a chamfer or a radius. To allow this freedom while still constraining the feature they asked for a CR callout.
I am not familiar with this callout and actually had to look it up on the internet, where I got the following definition:
Controlled Radius - creates a tolerance zone defined by two arcs (the minimum and maximum radii) that are tangent to the adjacent surfaces. Where a controlled radius is specified, the part contour within the crescent-shaped tolerance zone must be a fair curve without flats or reversals. Additionally, radii taken at all points on the part contour shall neither be smaller than the specified minimum limit nor larger than the maximum limit.
This does not sound as if it will work the way the customer thinks, but I have never used it.
Is there an accepted way to define a corner feature as either a chamfer or a radius but limiting it to a specific size?
Thanks,
Thanks,
