Hi all,
I have been presented by a set composite coupon testing (using ASTM standard) and need to validate that using numerically using FEA software (in my case, using MSC Nastran/Patran). What is the best parameter to compare with the coupon testing data and numerical FEA results?
For example, tensile testing we can correlate the Force and Displacement from the testing with the same FE numerical result. How about OHT (Open Hole Tension) Coupon Test? What is the best parameter to correlate between the testing and numerical FE result.
The same goes with VNS (V-Notched test), what is appropriate parameter to correlate with? I manage to build up and simulate the model as per testing but then stuck up on what is the numerical results should I look for?
Thanks.
Thanks.
