I have two wire beams parallel to each other, they are at an angle with horizontal. I tried coupling the U2, U3, UR1, UR2, and UR3 using a local coordinate system with nodes on one beam as controlling and nodes on the other as slave. They are aligned in elastic range but seem to not move parallel to each other in non-linear range. What might be the reason for this? How can I make the beams align with each other even in non-linear range?
