abusementpark
I need to analyze what is essentially a couple on a grade beam due to column reactions from wind bracing. Can anyone guide me as to determining what maximum moment will be generated in the grade beam? I can determine a modulus of subgrade reaction from the soils report. However, the portion of the grade beam that is in uplift will be resisted by adhesion on the sides. So, i guess the main problem is that I do not really know how to model the adhesion on the sides of the grade beam as a vertical support. Any guidance would be greatly appreciated..
