Countersink dim 1
Dockken
Aerospace
The question is Countersink dim. for a 4-40, 100 deg. c'sink
Helical sharp dim. for this screw is .225
print size callout is .231 + - .005 = .226 to .236
is this a aerospace standed
the low end seams to close to helical Max dim. of .225
or a case of lazy engineering, just use = + - .005
What's the position tolerance or equivalent on the hole?
What's the assembly condition, fixed or floating?
What's the primary design consideration, flush head?
+ - .005
Fixed
Flush
So, as it's fixed, what is the position tol on the mating part hole, .005?
If .005 this corresponds to pos tol dia .014 (give or take a tenth of a thou)
So, to guarantee flush you need the minimum counter sink size to be the 'max sharp diameter' of the screw head, + pos tol of csk hole + post tol of threaded hole.
So if your numbers and my assumptions are correct that'd be:
.225+.014+.014 = .253 minimum.
My guess, it's a case of lazy/uneducated engineer.
Note - that while this guarantees flush, it does not optimize stress under the head or anything else, just guarantees the head should always be flush or below flush.
Thanks Kenat
You put in black and white the hole picture as I also see it
Dockken
Very drole!
Are you in a position to go back to the person that came up with the .231+-.005 and question/educate them?
Sharp as ever there, KENAT.
"Good to know you got shoes to wear when you find the floor." - [small]Robert Hunter[/small]
They have been making it for year that way
If I get an opportunity will try, but they are reluctant to change
Well there's the rub, because of how good a lot of C&C processes are these days etc they're probably hitting near the middle of the tol ranger fairly repeatedly. The above is for worst case.
Plus the head of the screw and/or the material it's going into probably deform a bit.
Plus, unless they're really looking for it they may not notice heads just a few thousandths above flush.
However, there are situations where not being truly flush, or generating more stress under the screw heads can be a real problem.
OK, made to look silly by assumption. Still I'd think even manual machines would probably tend to be better than +-.005 in a single set up - or are they literally scribed out and drilled?
The part is machined to size and thinkness and drilled, 6 to 12 holes per part, may be 20 to 50 parts, but the C'sink is done manualy
dockken
