I have a 26'x30' cinder block foundation garage built on a grade. The back corner has about 3 1/2' of gravel fill under the slab, and the front maybe has 6". Fill dirt was added in the back to build up the earth about halfway up the wall to give it some counter pressure.
I was going to be getting a couple loads of fill delivered soon to fill some eroded areas of my yard and was contemplating adding more fill in the back of the garage to make the earth even with the bottom of the slab. This would probably be 18" more fill on top of the existing.
This seems like it would be a good idea to provide even more counter pressure from vehicle loading an the weight of the gravel, but I just wanted to make sure I wouldn't be causing any issues with stress on the wall from the earth.
I'm probably over thinking.
