Count number of solid elements in the tree
douddy34
CA
Hi guys,
i'm trying to develop a simple code to count the number of solid elements in the my main body.
The problem is, it only returns the number 1.
If any of you can help me. Thx a lot
Sub CATMain()
Dim MyPart As Part
Dim MyBodies As Bodies
Set MyPart = CATIA.ActiveDocument.Part
Set MyBodies = MyPart.Bodies
MsgBox (MyBodies.Count)
End Sub
You mean mechanical features? If yes, check macro bellow (it will count in all bodies, not only in main body, you need to modify macro if you want only in main body).
Code:
Language="VBSCRIPT"
Sub CATMain()
Dim partDocument1 As Document
Set partDocument1 = CATIA.ActiveDocument
Dim selection1 As Selection
Set selection1 = partDocument1.Selection
selection1.Search "Name=*Body*,all"
Dim selection2 As Selection
Set selection2 = partDocument1.Selection
selection2.Search "CATPrtSearch.MechanicalFeature,sel"
MsgBox selection2.Count
End Sub
Fernando
hi,
Try ctrl + F and specify the elements to search and click search and select. It displays the no of elements selected.
Hope it helps. All the best.
