Couls someone explain itereative calculation pls.
carthago
NL
Iterartion.
I have to use the end result into the the original formula and get a new result..several times, until the difference between two consecutive results is smaller than a certian value ( convergence)..
How to do this with mathcad ??
There are a number of functions for doing this type of problem, like minerr or minimize or rkadapt, why do you need to create your own solver?
TTFN
You should be able to do this with 'while' loop calling an external function (or local function for MC12+), see Mathcad programming.
Also Mathcad supports recursive functions (function appears on the right and left side of the equation).
Peter
