aswierski
- Apr 3, 2009
- 68
I am analyzing single column, unbraced pipe supports using ASD05 (although LRFD is acceptable as well) and have a question regarding the column design. I've used the methods prescribed in Salmon & Johnson's "Steel Structures" (5th Ed.) for axially loaded columns. As you can see from my attached calc, this obviously does not account for the moment I have at the base plate. Even though it is not shown as such, assume all of the loads to be already factored.
My question is this: How do I take the moment into account? I know I should be designing this column as a beam-column, but Salmon & Johnson only give examples for W-shape columns. Per our clients standards, we can only use HSS members. Can anyone give me some advice on this? Or point me in the right direction? Thanks in advance.
