Have a water basement problem again in the same area where a french drain was installed two years ago. Why did the system fail after two years? Contractor installed perforated pipes, backfill with clean crushed rocks, and wafers to divert the water to the existing sump pump. What would be a new solution to completely divert all the water and prevent it from seeping between the cove? thanks
