You might get some marginal savings because you might be able to run lower flue gas temps, depending upon whether you've got an economizer and/or air heater. My experience with this kind of exercise is that it often looks FAR better than it really is, because of steam metering that is not pressure compensated. If it doesn't get recalibrated to the new, lower pressure, the meter reads high. There will also likely be steam quality issues at the lower pressure. Spirax Sarco has (or had) a video shot from inside the steam space of an operating boiler. You can actually watch the "fog" form inside the boiler when the pressure gets reduced from it's design operating pressure. You can also run into problems with system components (piping, control valves, traps, etc.) being sized for the current pressure, and not being big enough for the same #/hr at the lower pressure.
I can't think of too many plants that have tried this, that have actually had the headaches outweight the benefits. The ones that were convinced that they had acheived the greatest efficiency increases were typically being fooled by their steam meters.
