Corrugated canal linings and Manning's 'n' 2
nick269
Geotechnical
Feb 9, 2006
14
This is Nick again from Vietnam.
We have a canal that we are trying to upgrade, and the city authorities are sold on canal linings consisting of corrugated pre-cast concrete sheet pilings. The surface profile of the sections look like this:
__ __
_/ \__/ \_
The projections are 0.48m in height.
These linings will form vertical walls. The channel bottom is unlined. Canal is subject to tidal backwater, and velocities in both directions are 1 to 2 m/s maximum. Because of a low gradient (.001)and low lying ground, flow reversals occur in the combined sewer system outlets (periodically submerged), so I am concerned about raising the water surface /reducing velocities any more than necessary. (Tidal gates with pumping has been ruled out)
My question is - how to compute Mannings 'n' for this type of vertical surface. I looked at k, the height roughness factor, and also Chezy's roughness factor, and thought of computing a composite n. My aim is to compare this surface with a conventional smooth concrete surface. I'm not sure how to go about this. Is there some standard method developed for such surfaces?
I also thought of modeling with HEC Ras, with alternate cross sections representing the projected and indented surfaces, and using expansion/contraction coefficients. Is this a feasible approach?
Nick Lombardi
depending upon how wide your channel is, you will need to compute a composite n. If your channel is wide, the corrugations probably have minimal effect on the flow
The coorugations will fill with silt, sand within a fairly short time. then they will be very much like a dirt canal and I'd use n= .019
Richard A. Cornelius, P.E.
