We designed a fin-tube heat exchanger assy using carbon steel pipe and fins. Our Customer has now advised he plans on running DI water in this water circuit. The water will probably enter heat exchanger tubing bundle (12 tubes x 120"lg) at 45-60F and exit at 100-110F after absorbing transferred heat. Will the DI water attack and corrode the 1-1/2" sched pipe(.145"wall thk) rapidly or take years before corrosion will create leaks/pin holes in tubing?
We can change pipe material to stainless steel but then we lose significant heat transfer properties.
