The idea is have representative data for the whole flowline/pipeline/plant segment.
The distance between the two will be more of a operability and layout issue. I would suggest the following partice:
- Provide both downstream and upstream the injection. Any distance is OK as long as you think the data will represent both inhibited and not inhibited.
- If the span between two coupon is too long (for example >30m) add another one
