carletes
Chemical
- Jan 28, 2003
- 79
Dear all,
Anyone knows why B31.1 when calculating sustained or expansion load cases uses nominal thickness without considering corrosion allowances? And on the contrary, when calculating the required thickness due to pressure such allowances are taken into account? Moreover, taking into account that B31.1 doesn't specify corrosion allowances (or at a least a maximum value) there is a risk of someone taking very high allowances.
Best regards and thanks
