If the water is not circulated during the standby state, then there may not be sufficient passivation taking place on the unit metal surface. Or debris can be settling on the surface, which will inhibit passivation. Heating can accelerate corrosion and stagnent seawater is not good either. Circulating the water during stand-by should minimize the problem.
Best of Luck
