Correct Orientation of Projected Views?
  • Thread starter Thread starter msalvati
  • Start date Start date
M
msalvati
Guest
When I pull views from a part in a drawing the orientation is backwards to how I would like it. Here is an image of what happens when I use the Projected View command.
Here is what my drafting standards is set to, but no matter what I change it too the views still pull the same.
And this is what I would like my projected views to pull like.
Any instruction on how to correctly adjust the settings for the desired results would be greatly appreciated.
You have the angle set up wrong.
I think the setupis under page setup or format, look the page setup in the feature tree, then chqange the angle from either first angle to third angle ot the other way about. From what I can see you are trying to change it in options.
Hi michael3130,
In a drawing under the sheet properties is an option called type of projection.
Here is what it looks like.
Third angle is what I was looking for.
Thank you for helping me solve this issue!
Yea, that was what I was looking for, I use ProE more than SW at the min and couldn't remember the exact location of it.....glad it helped you tofind it and sort the issue
