Thanks Ingenuity
You nailed it. Though I was just touring this project, it was pretty much what you descibed. Coring through a combination of beams, slabs, and columns--except only about 50 feet, a tolerance of 1", and surveyors using very primitive means compared to lazers (piano wire). I am still curious how the lazers were used for the surveying. Were they just used to check periodicly if the holes were on target, or were they actually part of the coring setup that "guided" the bits.
Q-shake,
There was some "head scratching" on this job too. While coring, they were logging the rebar, plates, trash, and whatever else they encountered as the sleeves came out; and they were finding things that no one knew why they were hitting certian structual elements and at those locations.
I'm still at the entry level stage in my career, and so far it was the largest project I've been on--completely overwhelmed by the shear size, amount of effort, and amount of money, that goes into huge, complex projects. Likewise, I was just as overwhelmed by the amount of tension in the people because the project was not going smoothly at all (possible collapse), when the facility should have been in full production already. I guess I was so overwhelmed because I've been on a *small* project that wasn't going smoothly and I can't see how the entire upper echelon hasn't had a heart-attack already. Amazing! Sorry, had to share it with someone that could appreciate it.
