D
design-engine
Guest
I modeled a simple part and used top down design to remove the geometry (not using Pro/MOLD).There is a simple boss with a hole inside to accept a self tapping screw.The hole follows the 70percent rule and goes a bit past the material thickness.Anyway.... My core and cavity look great except how do I separate the core pin into a core pin part?
