Working in GSD, I have a square along with 1 line perpendicular to the square at 1 of the corners. The goal is to COPY the line to the other 3 corners. In V4 this was very simple (point to point- translate/copy). Does this exist in V5? If so, how do you use it (I'm sure it won't be as easy as V4)? Methods tried for the above situation: Copy & Paste (pick a line, clipboard, picked location, paste -- just like in my workbook) = 1 line overlaying the line I picked to copy, 2 lines from the square going invisible yet still on the tree. What is that all about??? Second method tried - Rect. Pattern.
Lot of work, all my elements ending up linked together (erase one, erase whole screen), errors and the update swirl. Why is every wireframe seemingly all linked together eventually to where editing means you might as well just start over. Is there a way to explode things so that a line is just a line and not like a link in a chain?
Can anyone me help solve these V5 wireframe mysterys?? Thanks.
