copying a curve
  • Thread starter Thread starter simo
  • Start date Start date
S
simo
Guest
hi all,
how can I to copy a daturm curve and make this curve tangent to an other daturm curve previously made?
thanks
Simo
Hi
try to pick on the curve (becomes red), then edit>copy,
the systems waits from you to define the new references for the copied curve.
Scale or rotate your curve to your desired position.
Now use constrains to make this new copied curve trangent to you first curve.
of course your copied curve is independed from the first.
hope this helps
xcad
