Copy sheet from prior drawing
  • Thread starter Thread starter walty310
  • Start date Start date
W
walty310
Guest
Does anyone have experience adding sheets to an existing drawing by /advanced/merge technique?
I would like to add an existing sheet from drawing B to drawing
A. The assemblies use most of the same subassemblies. Is
there anything I need to be aware of ?
Are there any issues with view names or crossectin names?
Brian
u can simply go to to advanced/merge option..it'll ask u for the drawing to be added..select the name and then it'll be added as next sheet in the opened drawing..u can remove the unwanted sheet .
