Hello
First of all, thanks a lot for your support¡
I followed your instructions and it worked almost 100% but I have a problem.
Nowadays I am working in a project to Daimler and consequently I must work under Daimler enviroment in NX...
So once I make the copy Daimler gives a special numbering called "ET" in the nomenclature box, please check the image attached.
Apparently, both ET numberings from each part ( original part and the copy) are differents but when I make a save management
the part copied has the same ET numbering of the father...
Unfortunately I am not able to fix this issue because even when I tried to modify "by hand" this numbering in the save management options box
this Et number did not change..
Please, If there is someone with experience working with Daimler environment i would be grateful if could give a hand in this issue....
