Copy paste break link macro
kevin.rahhal
New member
CA
I am writting a macro to be able to copy/paste and breaklink products between 2 different windows. I am able to do it manually so I know it's possible.
I've also written a macro that does it but limited to same window for paste.
I'm wondering what I would have to change with my code to be able to paste to another window.
Any help is appreciated.
Here is what I have :
"Dim selection1 As Object, selStatus, InputObject(0) ' Objects used for selection
InputObject(0) = "Product" ' Only allow products to be selected
Set selection1 = CATIA.ActiveDocument.Selection ' Object used to handle selections
selStatus = selection1.SelectElement3(InputObject, "Select items to copy", True, CATMultiSelTriggWhenUserValidatesSelection, True)
If (selStatus <> "Normal") Then
MsgBox ("Selection cancelled of items to copy. Macro exiting") ' Inform user macro has been cancelled.
Exit Sub
End If
Dim arraySelectedElements() As SelectedElement
ReDim arraySelectedElements(selection1.Count2)
Dim arrayElementCount
For arrayElementCount = 1 To UBound(arraySelectedElements)
Set arraySelectedElements(arrayElementCount - 1) = selection1.Item2(arrayElementCount)
Next
selection1.Clear
selStatus = selection1.SelectElement2(InputObject, "Select where you want to paste the items", False)
MsgBox ("Selection of location to paste products cancelled. Macro exiting") ' Inform user macro has been cancelled.
Exit Sub
End If
Dim pasteSelectedElement As SelectedElement
Set pasteSelectedElement = selection1.Item2(1)
selection1.Clear
selection1.Add arraySelectedElements(arrayElementCount - 1).LeafProduct
Next
selection1.Copy 'Copies current selected items
selection1.Clear ' Clears the selection of items, so the new product can be selected
selection1.Add pasteSelectedElement.LeafProduct
selection1.PasteSpecial ("CATSpecBreakLink") ' Paste & break link on root product"
When I execute this macro, it will always paste within the same window even if I select a different one
Hello, you need to switch between windows.
For example, you copy from one window, switch to another and then paste.
Same as manually.
I have some similar macro for the kinda same operation.
[link catiavbmacro.com]catiavbmacro.com[/url]
I tried changing the last few lines to this, but still no cigar.
"selection1.Copy 'Copies current selected items
Dim specsAndGeomWindow2 As SpecsAndGeomWindow
Set specsAndGeomWindow2 = CATIA.Windows.Item("ENOVIA5\XXXX.CATProduct")
specsAndGeomWindow2.Activate
End Sub"
I checked your site, but wasn't able to spot the similar macro. Could you link me to it please?
I have some code that copies pastes from one window to another. It's similar but not exactly what you're doing. Maybe it'll give you a new idea.
I've been meaning to change this code myself as it tends to error if I have more than just the source document open. It indexes to the first item open in CATIA ( CATIA.Windows.Item(1) ) rather than the correct destination document.
Hope it helps.
Code:
'Change window and start adding CATParts from bodies
    Dim window1 As Window
    Set window1 = CATIA.Windows.Item(1)
    window1.Activate
    Set Activdoc1 = CATIA.ActiveDocument
'unrelated object renaming code is here...
 'copy part body to memory
        Activdoc1.Selection.Clear
        Activdoc1.Selection.Add Body1
        Activdoc1.Selection.Copy
        'Start adding CATParts to the new assembly
        Dim Part1 As Product
        Set Part1 = NewProd1.Products.AddNewComponent("CATPart", CStr(bodyName))
        NewProd1.Parent.Activate
        NewProd1.Parent.Selection.Clear
        NewProd1.Parent.Selection.Add NewProd1.Products.Item(Part1).ReferenceProduct.Parent.Part
        NewProd1.Parent.Selection.Paste
I was busy to answer you, today I find some time to do it.
Here are lines that I used
Code:
        Dim partDocument1 As Document
        partDocument1 = MyCATIA.ActiveDocument
        Dim K = partDocument1.Name
        Dim selection1 As Selection
        selection1 = partDocument1.Selection
        selection1.Clear()
         Dim part1 As Part
         part1 = partDocument1.Part
         selection1.Add(metoda(i))
         selection1.Copy()
          Dim windows1
            windows1 = MyCATIA.Windows
            Dim specsAndGeomWindow1 As SpecsAndGeomWindow
            specsAndGeomWindow1 = windows1.Item(TextBox37.Text & ".CATPart")
            'this textbox is part that I selected before all of this
            specsAndGeomWindow1.Activate()
            Dim partDocument2 As PartDocument
            partDocument2 = MyCATIA.ActiveDocument
            Dim selection2 As Selection
            selection2 = partDocument2.Selection
            selection2.Clear()
            Dim part2 As Part
            part2 = partDocument2.Part
            selection2.Add(part2)
            selection2.PasteSpecial("CATPrtResultWithOutLink")
            Dim specsAndGeomWindow1x As SpecsAndGeomWindow
            specsAndGeomWindow1x = windows1.Item(K)
            specsAndGeomWindow1x.Activate()
            selection1.Clear()
            selection2.Clear()
here are those lines you need, this is not full code, I just took lines you need.
See more cool macros [link catiavbmacro.com]catiavbmacro.com[/url]
