Copy my settings to new version of ACAD
ercegs
69
Does anyone know how to copy my settings to the new version of ACAD.
I know how to copy my settings from one computer to another, but how to translate that to the new version of ACAD.
Is there any chance to do that?
I need this, because I have a lot of my personal commands that I made. They are very usefull for me, and I spent a lot of time to make them. So it would be great if I don't have to make them all over again
ercegs,
I don't remember how to export the settings of Autocad R14.
ADT 2004
need more details,
which versions of Acad, from & to?
what kind of commands?
lsp, arx, marco?
depending on versions, you may only want to "copy" certain routines
Intel P4 3.0 GHZ
512 DDRAM
Win 2000 Pro
Autocad 14, 2002 with EP 2.3.1
Autocad 2008
I'm exporting from 2007 to 2009. I have a couple of toolbars containing both lsp & macro commands.
leave 2007 on machine, install 2009
2009 will detect 2007 customization and prompt you to use these settings for the new 2009 install
some older commands may not work, see if old command has been replaced with New
double check support paths on new install
Intel P4 3.0 GHZ
512 DDRAM
Win 2000 Pro
Autocad 2008
I have already heard about method that OZZY84 said. I'll try that today.
Thank you.
In 2007
Tools---> Options ---> Profiles
Select current profile then click export and save .ARG file
In 2009
Import profile
I managed to adjust acad 2009, but some problem appeared. I would appreciate if someone have a solution.
I have a problem with object snap toolbar...check the attach to see how it looks like when I turn it on?
Is that normal maybe?
 http://files.engineering.com/getfile.aspx?folder=4386a510-fa96-4169-a6b9-22ddaf83e381&file=Object_snap_toolbar.jpg
