MikeHalloran
- Aug 29, 2003
- 14,450
2009.4.1
I'm trying to copy an ordinate dimension.
I.e., the dim line points to an edge of a hole in a panel.
I want to copy it so the new dim line points to a parallel edge of another hole in the same panel.
I hold down the CTRL key, and drag the tip point of the dim line to the end of the new edge.
SW shows me a phantom outline of a new dim and dim line as I drag the point.
Then, as soon as I release either key, the phantom outline disappears, and is replaced by... nothing.
I'm too old to hold down a third key while doing this...
One possible problem, now that I've been thinking about it a while. All of the (many) dimensions on this drawing are browned out. I guess that means 'orphaned'? That seems to be an artifact of pushing the panel down into a subassembly, after the drawing was first dimensioned. There doesn't seem to be a fast way to recover from that.
( So, I tried using autodimension to add a new ordinate dimension, picking just one edge of a rectangular hole. Hoo boy; it dimensioned it to the wrong side of the drawing, and added dimensions to three tiny chamfers on a nameplate that's not supposed to be related to the hole.
But that's a complain for another day... )
Mike Halloran
Pembroke Pines, FL, USA
Mike Halloran
