copy a BOM or a Cut List from one Drawing Sheet into another
josephv
683
Good day,
Is there was any way to copy a BOM or a Cut List from one Drawing Sheet into another Drawing Sheet (using SWX 2007)?
Cheers,
Here is a clarification:
What we would like is to have the same view and BOM in several different sheet. In SWX 2008 there is a copy sheet command (I believe), this does not exist in SWX 2007.
What is the best way to copy a drawing view and its' BOM into several different sheets?
Well it looks like the only way to do this is:
1) Copy view into new sheet
2) Create new BOM table in the new sheet (since it can't be copied)
Unless you are using SWX 2008, in this case simply copying a sheet solves the problem.
cheers,
