I'm fairly new at cryo engineering. What are the problems with using copper tubing and soldered joints (other than shrinkage) for carrying:
1. Dehumidified air at its dewpoint
2. Liquid nitrogen at 120 psig
3. Nitrogen gas at 120 psig, 150 K
I'd assume that the solder joints would break due to shrinkage, and since copper is an excellent heat conductor, it would be hard to keep the room temp. heat out of the lines. Any suggestions, thoughts?
Thank you!
Thank you!
