RS... a few specs to consider...
NOTE. Copper tube/pipe alloys You are brazing may require low temperature silver brazing alloys to ensure copper is not heat damaged, thus...
CAUTIONs/NOTEs.
Some low temp silver-braze alloys have added cadmium to reduce solder melt temperatures and improve 'flow'... suggest avoiding AMS4770 and AMS4771.
Consider using AMS4763 or AMS4773... low temp silver braze alloys WO cadmium.
Always use brazing flux [AMS3410].
Your weld/braze techs should be able to assist in brazing alloy selection.
AMS2665 Brazing, Silver, For Use Up to 400 °F (204 °C)
1. SCOPE
1.1 Purpose
This specification covers the engineering requirements for producing brazed joints in parts fabricated from steels, iron
alloys, nickel alloys, cobalt alloys, and copper alloys by use of silver alloys, and the properties of such joints.
1.2 Application
This procedure has been used typically for joints requiring high strength up to 400 °F (204 °C), but usage is not limited to
such applications.
1.3 Warning
Numerous scientific studies have determined that cadmium, which is used in some brazing alloys, presents a health
hazard to persons if inhaled
Regards, Wil Taylor
o Trust - But Verify!
