Sure, just work off the absolute. Very very rarely will I move the WCS, there is almost no need anymore. The datum CSYS is handy as a visual reference, and secondary datum coordinates, if needed.
You are missing the boat, Gunman, if you don't move your WCS around and use it.
Wouldn't want to ever see WCS deprecated, it is too useful.
Proud Member of the Reality-Based Community..
[green]To the Toolmaker, your nice little cartoon drawing of your glass looks cool, but your solid model sucks. Do you want me to fix it, or are you going to take all week to get it back to me so I can get some work done?[/green]
When would I want to move it? Back before it became NX, ie the UG era, I moved it all the time, but as NX improved, the need to move it has gone down to rarely, if ever, at least for me.
I would say it depends on what type geometry one works with.
If it's splines and freeform, WCS is a must. ( Or at least a great benefit.)
If it's prismatic things the WCS can be ignored by the user. - It's still there active and working but doesn't need to be handled separately.
Why do we need different types of coordinates (Cartesian, Polar, Spherical)? Why can a user model the same part 10 different ways in NX? Why do we need fractions and decimals? Why can a Plane or Axis be defined in more than one way? Why have a sketcher when a user can typically accomplish the same task with plain curves?
Simply put, not everyone does a single task the same way in NX and it would make the product less flexible and cater to fewer users and industries if certain things were pared/deprecated (thank you capnhook) from the software.
