Coordinate System in SolidWorks
mengineer2001
1
I have been an active Pro E user for many years and new to Solidworks. I am currently trying to create a coordinate system. In Pro E you can create a coordinate system off of an existing coordinate and you can also rotate the new cs in x, y or z. Can this be done in SolidWorks without having to create a plane or some other type of reference geometry and just using an existing coordinate system?
Why are you trying to insert new coordinate system?
You can't just insert one on its own. It has to have some sort of entity for its origin to attach to. This could be a single sketch point in a 3D sketch, and that point can be dimensioned relative to the origin.
-handleman, CSWP (The new, easy test)
You can create a new CS using existing model geometry.
Are you trying to re-orient the model? If so, after creating the new CS, save the part as a Parasolid naming the CS as the output CS. When opening the Parasolid back into SW, the new CS will be the default. The downside to this method is that a dumb solid is created.
An alternative is to use the Orientation (spacebar) function to 'exchange' axes orientation, but although 'permanent' can be reversed at any time.
[cheers]
If you are just after a co-ordinate system for a cad/cam file for say, SolidCan Or EdgeCam, then wherever you want to place the co-ord sys,create a plane, then a sketch on the plane with a line perpendicular(Z)to the centre of your proposed co-ord sys and a line horizontal(Y), close sketch but keep it visible (right click on sketch and select show.
Then go to insert reference geometry/co-ord sys, pick point, pick the point at the centre of your sketch, then select either Y or Z in the dialogue box and you get the option to reverse axis direction, just keep playing about with it until you get the co-ord sys you want.
