Coordinate dimension table
jrhagen
Aerospace
Feb 7, 2008
36
I was wondering where you can change the default number of decimal places that the table uses when using the coordinate dimension table command. I understand how to use the command but I cannot seem to change it from 2 to 3 place dimensions. The table also just brings in dumb text, so changing the fields line by line to 3 places is not an option. Thank you in advance to anyone that can help with this. BTW I am using Catia V5 R17.
I figured this one out on my own. Apparently you have to set the dimension decimal places before selecting the tabulated coordinate dimension command. Once you start the command there is no way to go back and edit the table later.
can someone please explain how the coordinate table works? I have clicked the icon, but can't get it to do anything. I need to draft a dwg that will include either a table or the xyz coordinates on the part itself.
Pick the points before you activate the feature
