I am not a mechanical engineer, my background, for many years, is in Information Technology code design. Please keep you response in easy to understand terms.
This is my first attempt at water cooling a computer, I have no margin for error.
Environment...
I have the option of using 1/4 3/8 or 1/2 water loops and likely will use 3/8 unless someone can build a good case to move to 1/2 inch. This is the first time I have attempted cooling via water and I will be targeting the motherboard voltage regulators, North bridge chip, South bridge chip, and CPU. The loop will consists of 5 water blocks in a serial configuration each of which have a copper transfer plate.
Each block will be mounted on top of each of the area to cool and have a layer of thermal interface material (pads, tape, or paste) between the blocks and the component surface (some metal and some IC chips). The internal are of the water blocs consists of a hollowed area with cool water entering and heated water exiting the block.
Questions...
1. I need a simple method to find the best flow rate for transfer of heat to coolant. My understanding is cooling can be reduced if the flow is to low or to high. Disturbing the system once installed will be difficult.
2. I also need to know what type of thermal interface material would be best for IC chips of a non-metallic material. It must be non conductive, not disperse into the leads of the chip, and have a high rate of heat transfer. Two of the water blocks will be cooling multiple voltage regulator chips per block. For these block it is essential no gaps develop (in the thermal interface material) between the chip surface and water or overheating will occur.
3. Is there a preferred type of coolant to use in this system to enhance heat transfer? My initial thought was distilled water with some type of biocide additive to inhibit organism growth along with a corrosion inhibitor in the fluid. I have no ide what would work best so no corrosion, algae or organisms growth occurs.
4. Tubing material is another area I am uncertain of. Many are available and I have access to most types. Pressure will be no greater than common off shelf cooling pumps Will provide. Fluid temperature is an unknown as it moves through system areas, some components may go as high as 95C while being cooled. Suggestions are appreciated.
5. Maintenance of the system will need to be performed. The system consists of Acetal material, Tubing, copper, brass, and nickel. What is the beat way to clean the inside of the blocks (they can be disassembled), tubing, pump, and radiator? The radiator is my biggest concern due to the many small areas of which I have no direct access to clean. What method would be best for removal of corrosion and any other material build up in the system? Any cleaning solution should be easily removed after cleaning so as not to cause damage to the system while in use.
Environment...
Questions...
