I would really appreciate all your responses to my questions. Part of the current project that I am working on entails two trim coolers that are designed for a cooling water flowrate of 1100gpm but are currently receiving 600gpm. The two exchangers are in parallel. What could possibly be causing this shortage in flow? The inlet is at 90F which is to be reduced as well as part of the project. The coolers are part of a fractionator off-gas system. One thing that I have been working on is a cw utility summary table where I have jotted down all the take-offs from the main cooling water header that serves the trim coolers (right from the cooling tower). The same header, ofcourse serves several other unit areas in the refinery. Like cw supply to sample coolers, seal oil coolers, other exchangers...etc.The table has the duties,mass flows and temperatures. Is this going to help me evaluate something?? Fouling in the tubes could be a reason too. But is there anything else that is a prominent cause for this?The main users of the cooling tower are already at about 89MMbtu/hr and the overall duty of the cooling tower is at 97.5MMbtu/hr.
Any suggestions and guidance really appreciated!!
Thanks!!
Thanks!!
