Hi
I'm currently looking into optimising the cooling system on one of our process plants and I have a question I hope someone can help me with.
The cooling system is a tempered loop (i.e. warm water from process is recycled into cold water into process to prevent freezing of materials in cool ambient conditions) and has a dedicated mechanical draft cooling tower (3.5MW) to perform the cooling. Due to significant plant uprates in the past the tower is underspecified for the duty it is seeing and there is scope to change the operation of the tower to try to cope with this.
The tower is designed for 500m3/hr with inlet temp to the tower of 25.1'C and return 19.0'C in summer and 16'C in winter, with a wet bulb of 17'C.
What I basically want to know is if I increase the outlet water temp of the tower (and hence the inlet temp to the tower) to say 23'C will I see an increase in the DT across the tower and if so how much?
There is data missing for the tower such as air-flow through the tower so a 'first principals' calc is no use. What I really need is a simple correlation of how changing only tower water outlet temp affects deltaT over tower and hence duty.
Any help on this would be excellent.
Cheers
Shaun.
Cheers
Shaun.
