Jebb
- Aug 30, 2005
- 53
I’m looking for some formulas to determine the efficency of a dry type cooling tower. I’m trying to do some cost justification to determine when towers should be cleaned to remove pollutants, dirt, etc. from the fins. The cleaning process is very time consuming / labor intensive with the amount of pollution fouling the fins varying from year to year so it’s not a “clean every year” type of thing.
The cooling tower arrangement has 50 cells with a fan for each cell operated by a control system. A 50/50 glycol/water mix is circulated through a closed loop system with the control system using an algorithm to regulate the return temp to 25C (within reason) by turning on or off the required number fans to control the water temp. I have the following information from the control system:
Flow: (l/s)
Supply Temp (to towers): (C)
Return Temp (from towers): (C)
Ambient Temp: (C)
We just cleaned the towers so I would like to baseline the data I have now. Any help would be greatly appreciated…
Thanks, Jebb
Flow: (l/s)
Ambient Temp: (C)
Thanks, Jebb
