Hello everybody.
I'm new engineer and while lacking experience I'd like to have your opinion about a cooling system design.
Hopefully my English won't be a problem.
I have to design a centrifuge for the purpose of a machine tool. One of the requirements is to keep the neat cutting oil NCO (and coolant at the same time) at 25 +/-2 °C. I have available water at 14-15 °C, 3bar.
Volumetric flow rate of NCO can fluctuate: 30 - 90 l/min depending on the usage of the machine.
The NCO after the centrifuge enters a tank, (centrifuge exit is about 40-50cm above the tank upper surface), from where it's being pumped back to the machine (additional filtering before the machine and after the pump is possible). Abrasion particles aren't fully removed by the centrifuge (mainly ≤ 1µm in diameter).
The total heat addition to the NCO during a whole cycle is estimated to be a maximum of 2kW.
Room temperature 18 to 28 °C. Minimizing the noise the device produces is of high concern.
The heat exchanger has to be cheap and easy to clean. A customized device can be manufactured by my company.
The space for the cooler is limited to (400x400x700mm). Not to small for the low amount of heat to be extracted.
My proposal is to use a hybrid form of counter-flow tubular exchanger. Instead of one inner tube there will be used several smaller pipes (like shell-tube exchangers)in order to meet the limited space requirements. Water will pass through the pipes while the NCO will flow outside them under the minimum possible pressure loss.
Material of pipes is Aluminium, light, cheap and resistant to corrosion.
The outer tube will consist probably of two semi-cylindrical part so that it will me able to dismantle and clean the pipes.
The cooler will be placed half emerged or right above the fluid in the tank.
That's the rough idea. I need you opinion, problems you may see and your own proposals.
No need to calculate heat exchange area. Go for a rough estimation of 0.3 to 0.4 m²
Any enthusiasts?!
Kind regards
Any enthusiasts?!
Kind regards
