1
- #1
scchemeng
Chemical
- May 30, 2002
- 4
We have several reactors made of 316L SS. One of our new reactors is exhibiting significant corrosion on the cooling coils inside the reactor, which is not evident on the rest of the reactor or any of the other reactors. There aren't any products that are unique to this reactor. The manufacturer of the vessel has been less than candid with us about other design flaws with this vessel and we are inclined to believe that the cooling coil wasn't made with 316L as was specified. Is there any way to determine the type of SS the coil is made of in situ, or will we have to remove part of it to be analyzed elsewhere? Is there any reason we might see corrosion on the cooling coil and not the rest of the reactor? Has anyone encountered a similar problem? Any help would be appreciated.
