Glycol is 5-10% less efficient than water in transferring heat. However, this is more than recouped by the elimination of scale, dirt, and corrosion that can reduce heat transfer!Also,
Glycol systems are usually slightly more expensive than water systems. There is a one-time initial cost to fill the system with 30-40% glycol.
Convenience - In cooling systems where components are frequently disconnected and reconnected, the glycol is typically captured and added back to the system
