We have data from a supplier for the performance of a cooler core of the thickness we plan to use. It is a dual-pass configuration with inlet and outlet on the same side of the core and a transfer tank on the other end, and has been tested as such.
However, the dimensions of the tested core are different to our application, and more importantly it has been tested at a lower coolant flow rate than our engine.
I plan to scale the data according to tube count and length, treating the dual-pass configuration as one long, thin core of half the height and twice the width. So, I can calculate the performance of one tube, then assume if it's e.g. 20% shorter the deltaT is 20% less. Sound sensible?
But, is it sensible to extrapolate for a larger coolant flow rate? I can fit a curve to the current set of points, but we need data for over double the flow rate per tube, which seems a bit of a stretch...
Any help or references appreciated,
Regards, Ian
Regards, Ian
