Previous Post in ERROR
353.55 CFM = 500_CFM * ( 3.0_Hg / 1.5_Hg ) ^.5
Should be
353.55 CFM = 500_CFM * ( 1.5_Hg / 3.0_Hg ) ^.5
Greg, there is another small correction factor used by SuperFlow with the normal conversion factor
this might be a small Reynolds type correction ???
Most people just use the Test Pressure Conversion equation i just posted as its pretty close (Linear)
if you use the additional SF correction factor , its
even closer
if the Test Pressure is too low , the air speed will be low
and if theres a bad curve or any problem area in port or valve area , it won't show up at low airspeeds because air is flowing slow enough to follow bad curve , but at higher speeds (Test Pressures) , the same port will flow different numbers or in a live engine make less HP than the flow bench predicts.
Larry Meaux (meauxracing@mindspring.com)
Meaux Racing Heads
MaxRace Software
ET_Analyst for DragRacers
